Hello guys,
So i plan on upgrading my PC so i can play games such as fallout 4 on medium settings.
Will the parts i buy run ok with my CPU & will the power supply be enough?
Any help or ideas will be much appreciated, Thanks
My Specs
CPU: AMD A8-6500
Motherboard
Manufacturer: Hewlett-Packard
Model: 2B17
Brand: AMI
Version: 80.04
Date: 03/26/2014
Memory Type: DDR3 (6GB)
Graphics:
AMD Radeon HD 8570D
AMD Radeon R7 240
OS: Windows 10
The upgrades i plan on buying..
Graphics Card: MSI GTX 950 2GD5
RAM: HyperX FURY 8 GB
Power Supply: Corsair 430 W
https://linustechtips.com/topic/635670-pc-upgrade-help-please/
3 minutes ago, Alien24 said:
About £200 / $260
ok, what's your current psu btw?
https://linustechtips.com/topic/635670-pc-upgrade-help-please/#findComment-8205077
this is what i'll recommend(6gb of ram should be enough so i'll leave that for now):
Video Card: Gigabyte Radeon R9 380 4GB SOC Video Card  (£149.99 @ Overclockers.co.uk)
Power Supply: XFX 650W 80+ Bronze Certified ATX Power Supply  (£50.51 @ CCL Computers)
Total: £200.50
Generated by PCPartPicker 2016-07-31 13:21 BST+0100
https://linustechtips.com/topic/635670-pc-upgrade-help-please/#findComment-8205081
1 minute ago, Alien24 said:
It says max power 180 watts
definitely not gonna power anything. see if the connectors are standard ones first before buying a new psu.
https://linustechtips.com/topic/635670-pc-upgrade-help-please/#findComment-8205108
Here is a picture i took for you to try find out anything about it.. such as the connections and stuff
https://linustechtips.com/topic/635670-pc-upgrade-help-please/#findComment-8205131
Total: £200.50
wont my CPU run into issue with such a powerful card?
https://linustechtips.com/topic/635670-pc-upgrade-help-please/#findComment-8205177
not sure, but i think it should be just enough for the 380.
https://linustechtips.com/topic/635670-pc-upgrade-help-please/#findComment-8205185
what about temperatures, will i be ok with the stock fans?
should be fine. if the temps for the 380 are too high(past mid 80s) you can get another fan if there's an extra slot for it or set a manual fan speed for the 380.
https://linustechtips.com/topic/635670-pc-upgrade-help-please/#findComment-8205197
ok thanks for your help if i have anymore questions ill be sure to hit you back B|
https://linustechtips.com/topic/635670-pc-upgrade-help-please/#findComment-8205207
4 minutes ago, Alien24 said:
considering i have a amd cpu would it be best to go with a amd gpu or don't it really matter?
doesn't really matter IIRC.
https://linustechtips.com/topic/635670-pc-upgrade-help-please/#findComment-8205250
https://linustechtips.com/topic/635670-pc-upgrade-help-please/#findComment-8205251
