Building first PC
Go to solution Solved by Matias_Chambers,
Just now, Rentus1998 said:
Thank you! :D
Remember to quote people when you answer or else they might not see it :)
8 minutes ago, Rentus1998 said:
Hi Guys,
I wanna build my first PC and I need help with picking the right parts! My budget is about 1500€ /1650$!
I would want to get the gtx 1060 or 1070 but Im not that good at picking parts, because I don't know exactly what parts are good etc.
Hope you can help me!
You could have a look at the $1500 system that's in my signature and add peripherals on top of that.
I will most likely not respond to you in a thread unless you quote me.
$500 PC | $800 PC | $1000 PC | $1200 PC | $1500 PC | $2000 PC | $2500 PC | $3000 PC | $4000 PC
Damnit Carl (My portable POS):
CPU: Core i7-6700HQ
Motherboard: Toshiba L55-C5392 Mobo
RAM: 8GB DDR3 (even though I have Skylake)
GPU: Intel HD Graphics 530
Case: Toshiba L55-C5392 Case
Storage: 525 GB Crucial MX300 SSD
PSU: Whatever power jack comes with it
Display: Some 1366 x 768 garbage + an OK 1080p monitor
Cooling: Not enough + an external laptop tray
Keyboard: The included one
Mouse: $4 Lenovo 3D Optical Mouse (not as bad as you (rightly) assumed)
Sound: The Skullcandy branding right under the power button should clue you in
Operating System: Windows 10 Home
PCPartPicker URL: pcpartpicker.com/i-wish-i-had-enough-money-for-a-desktop-my-laptop-is-so-sh*t-its-not-even-on-portablepicker
https://linustechtips.com/topic/635251-building-first-pc/#findComment-8200678
12 minutes ago, Rentus1998 said:
Hi Guys,
Which European country? Gaming I presume? Do you need mouse, keyboard, etc?
https://linustechtips.com/topic/635251-building-first-pc/#findComment-8200701
1 minute ago, Rentus1998 said:
Thank You! Appreciate it! :D
No problem.
CPU: Core i7-6700HQ
https://linustechtips.com/topic/635251-building-first-pc/#findComment-8200704
3 minutes ago, Rentus1998 said:
Austria! And yeah, for gaming and I need everything(mouse keyboard etc)^^
With my system, you could probably get a nice cheap monitor for around $100, and some sort of mouse/keyboard combo deal like the CM Storm Devastator bundle for $50, or you could potentially drop some of the more expensive things from the build, like the Kraken x61 or go to the i5-6600K from the i7-6700K if you wanted some nicer peripherals.
CPU: Core i7-6700HQ
https://linustechtips.com/topic/635251-building-first-pc/#findComment-8200736
PCPartPicker part list: http://de.pcpartpicker.com/list/wDy9Gf
Price breakdown by merchant: http://de.pcpartpicker.com/list/wDy9Gf/by_merchant/
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  (€307.58 @ Amazon Deutschland)
Motherboard: Gigabyte G1.Sniper B7 ATX LGA1151 Motherboard  (€106.94 @ Mindfactory)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2800 Memory  (€80.10 @ Mindfactory)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (€97.74 @ Mindfactory)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€52.60 @ Amazon Deutschland)
Video Card: Gigabyte GeForce GTX 1070 8GB Windforce OC Video Card  (€462.34 @ Mindfactory)
Case: NZXT S340 - Designed by Razer ATX Mid Tower Case  (€107.84 @ Mindfactory)
Power Supply: XFX XTR 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (€85.84 @ Mindfactory)
Monitor: ViewSonic VG2233SMH 22.0" 60Hz Monitor  (€122.00 @ Amazon Deutschland)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  (€38.01 @ Amazon Deutschland)
Headphones: Kingston HyperX Cloud II 7.1 Channel  Headset  (€88.92 @ Amazon Deutschland)
Other: Windows 10 Home (€35.00)
Total: €1584.91
Generated by PCPartPicker 2016-07-30 18:23 CEST+0200
https://linustechtips.com/topic/635251-building-first-pc/#findComment-8200814
Should I buy other fans for the Kraken x61 or are the stock fans fine?
https://linustechtips.com/topic/635251-building-first-pc/#findComment-8201163
The stock fans are pretty good, although if you find yourself wanting something different you could go with this, a twin pack.
CPU: Core i7-6700HQ
https://linustechtips.com/topic/635251-building-first-pc/#findComment-8201196
