Hi there I was just wondering what the difference was between the MSI GTX 1070 GAMING X 8G MODEL and the MSI GTX 1070 GAMING Z 8G MODEL was. They both look and have the same features, but the Z model is cheaper and offers better clock speeds than the X model on newegg.ca. But the the biggest problem is, when I search the Z model up online It refers only to the X model.
System
  • CPU
    I7 6700K Overclocked to 4.6 GHz at 1.33v
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
    GSKILL RIPJAWS V DDR4 16GB 3000MHZ
  • GPU
    MSI GTX 1070 GAMING X 8G overclocked to 2063 MHZ and 8900 MHZ memory clock
  • Case
    NZXT S340 RED
  • Storage
    WD 1TB BLUE AND SAMSUNG EVO 250GB SSD
  • PSU
    EVGA 650W GQ
  • Display(s)
    LG 25UM58-P ULTRAWIDE and LG 29UM58-P 29 ULTRAWIDE
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
    LOGITECH G502 PROTEUS SPECTRUM
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/635164-difference-between-two-gpus/
Only difference is going to be the core clock speed. The Gaming Z will have a higher base/boost clock over the gaming X. With that said, all the cards regardless of which edition actually all overclock to about the same just under 2100mhz or right at 2100mhz.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Higher factory overclock and a few fancy RGBs on the card itself. Not that different from the Gaming X.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
Thanks a lot
System
  • CPU
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
  • GPU
  • Case
    NZXT S340 RED
  • Storage
  • PSU
    EVGA 650W GQ
  • Display(s)
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
  • Operating System
    Windows 10 PRO
Just the higher clocks and the huge MSI dragon on the back-plate, differentiate the Gaming Z from the Gaming X. If you're gonna overclock the GPU anyway, get the Gaming X, as the GPU itself can go only upto around 2.1 GHz. irrespective of the brand, cooler, or PCB.
Nothing to see here ;)
Ok thanks alot
System
  • CPU
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
  • GPU
  • Case
    NZXT S340 RED
  • Storage
  • PSU
    EVGA 650W GQ
  • Display(s)
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
  • Operating System
    Windows 10 PRO
