Issue with Front Audio jack
Go to solution Solved by Ichi,
Open the HD Audio Manager, go to option, choose AC97 Front Panel instead of HD Audio Front Panel.
At least that works for my system...
Hello guys! I've got an issue with my front audio jack. It was working yesterday as normal. Just today it stopped working. I've opened my case, removed the "HD Audio" cable, connected it back. Still not working. Also, removed the drivers and installed them, that also did not fix the problem.
Is it a problem with the case or the motherboard?
Please help. :(
https://linustechtips.com/topic/635103-issue-with-front-audio-jack/
Doesn't work. :(
7 minutes ago, Ichi said:
Can't help you then, wait for the veterans.
It's working! :D THANK YOU
3 minutes ago, Ichi said:
Why you no test properly before replying it doesn't work!
I'm raging now, jk....
I took out the "HD Audio" cable and connected to back :D:P
