hwmonitor and CAM both show temperature over 100°C, then I downloaded AIDA64 Extreme (trail) and it shows 50 °C on the cpu and 17-30°C for the 4 cores. Some time ago I've also got readouts of 5°C on cpu and -55°C on motherboard. I am no expert at this but I am pretty sure even amd does not run this hot idle. Tried  to play some games and noticed no performance issue e.g. fps dips due to thermal throttle . So is it just the sensors that are fucked? Also what impact will it have? I am using a (dusty) stock cooler with stock (at least 2 years old) thermal paste in a room at around 25°C.
edit- Update: idle temps now is 72 °C for CAM and hwmonitor
https://linustechtips.com/topic/635090-cpu-temps/
Take and re-paste your CPU, give your cooler a good cleaning and ensure your BIOS is up to date. I would take and uninstall all your monitoring software and use only one to ensure your not getting stepped on since your using multiple ones it looks like.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/635090-cpu-temps/#findComment-8199071
Re-apply thermal paste and clean the CPU cooler
CPU - i5-8400 , Motherboard - ASROCK Z370 Killer SLI, RAM - 2x8 GB DDR4 2400mhz , GPU - EVGA GTX 950 SC, Case - SilentiumPC PAX M70 Pure Black V2 Storage - 240GB SanDisk SSD, 1TB WD Blue, PSU - bequite! 600w Pure Power 10, Display - Dell P2417H, Cooling - bequiet! Pure Rock, Keyboard - Viper V730, Mouse - natec Genesis G55, Sound - Philips MCD712, OS - Windows 10 Professional 64-bit
https://linustechtips.com/topic/635090-cpu-temps/#findComment-8199077
