water or air
5 members have voted
  1. 1. water cooler or no
Since when 76degrees is a lot...
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/634908-will-i-benifit/#findComment-8197328
Just now, Bertb2008 said:
that is high
You are high.
https://linustechtips.com/topic/634908-will-i-benifit/#findComment-8197331
1 minute ago, Bertb2008 said:
im not high the card has never got this hot before most its gone to is 60
What? What R9 390 manufacturer?
https://linustechtips.com/topic/634908-will-i-benifit/#findComment-8197344
gigabyte
Oh god throw that card into the garbage. Gigabyte's AMD cards are trash, if your card gets up to 76 degrees and it is a Gigabyte R9 390, you should consider yourself a VERY lucky man, as those can surpass 90 degrees.
https://linustechtips.com/topic/634908-will-i-benifit/#findComment-8197355
well if i stick a water cooler on it would i get better temps
https://linustechtips.com/topic/634908-will-i-benifit/#findComment-8197393
Yes, but it is a waste of money. There are no compatible waterblocks for the Gigabyte 390 and installing an AIO and the G10 is not enough, you need to cool the VRMs and the VRAM as well, the G10 bracket is not sufficient for that. If I were you I'd simply upgrade. Sell your 390 and buy a 390X if you've got spare cash. This time, choose MSI or Sapphire as the manufacturer, cause they're actually good, unlike the dreadful Gigabyte.
https://linustechtips.com/topic/634908-will-i-benifit/#findComment-8197408
the most i will get is £113 for it lol i mite unplug 1 one and take it back
https://linustechtips.com/topic/634908-will-i-benifit/#findComment-8197416
