I've got a TP-LINK TL-PA4020KIT AV500 Nano Two-Port Powerline Starter Kit which I brought from amazon: here
Both of the adaptors are plugged into the wall sockets and here's what my speedtest.net results show:
I'm paying for 120 download and 10 upload, the upload with the powerline is fine however the download speed is not even half of what I'm paying for.
I just want to achieve the best performance possible since the Powerline utility software this product came with is showing that I'm receiving 103 download:
I haven't played around with any of the options here, so maybe someone more experienced could tell me how to improve my speed?
https://linustechtips.com/topic/634688-powerline-speed-issue/
14 minutes ago, mok said:
youre LUCKY youre getting the speeds that you are
i was only getting 2 down 1 up
and im paying for 100down/10up
I was getting similar to what you had when I used to use powerline... I just ended up running a cable from the Router to the Office in the end!
Computer Programming Nerd Guy + Computer Support @ Red Tree IT
https://linustechtips.com/topic/634688-powerline-speed-issue/#findComment-8195052
