Help with Visual Basic
Go to solution Solved by Stormsys,
Can you guys help me figure out what's wrong with this code? It's from an assignment for a computer science class. I uploaded to google docs because the whole folder needed to be uploaded. The file I need help with is a microsoft visual studio solution file called Reporter located in VBProjectTemplateF'13. When opened with Visual studio, the code is under Form1.vb. Help would really be appreciated and explanations showing what I did wrong would be helpful in understanding. Thank you.
https://drive.google.com/folderview?id=0B59mxMiNJtl3akhxTkRaQWgxemM&usp=sharing
I'd love to help but i think you should start by giving us your expected behavior and what actually happens instead and then i can take a look :).
https://linustechtips.com/topic/63422-help-with-visual-basic/
https://linustechtips.com/topic/63422-help-with-visual-basic/#findComment-873421
