Power Supply peripheral
Go to solution Solved by Imam Ali,
1 hour ago, STRMfrmXMN said:
VGA should be labeled at the cable end, not at the PSU end.
Vga is labeled on the EVGA power supply? So where should I connect it?
The PCI connector?
Needs money for car parts :P
System specs: Core i7 9700k, Dark Rock Pro 4 , MSI Z390 PRO, 16GB CORSAIR VENGENCE DDR4 3000, ASUS RTX3080Ti, Corsair AX860, Seagate 1TB, Sandisk 240GB SSD, Samsung 1TB SSD, Corsair 400c
My Steam Profile (from SteamDB)
  • Worth: £654 (£221 with sales)
  • Games owned: 62
  • Games played: 52 (83%)
  • Hours on record: 2,980.7h
https://linustechtips.com/topic/634196-power-supply-peripheral/#findComment-8189535
7 minutes ago, Imam Ali said:
Whar is the peripheral 6 pin used for in a power supply?
A graphics card, for example.
https://linustechtips.com/topic/634196-power-supply-peripheral/#findComment-8189579
14 minutes ago, Imam Ali said:
Then what's the VGA connector for?
https://linustechtips.com/topic/634196-power-supply-peripheral/#findComment-8189863
I'm completely lost. What does the cable say and what does the PSU end say? What exact PSU do you have?
https://linustechtips.com/topic/634196-power-supply-peripheral/#findComment-8190679
I'm gonna choose one of these http://www.evga.com/articles/00927/EVGA-SuperNOVA-650-550-G2-Power-Supplies/ if you check the images out you will understand.
https://linustechtips.com/topic/634196-power-supply-peripheral/#findComment-8190923
OK, the thing on the PSU that say VGA 1 and VGA 2 - that's where the 6-pin plugs into, except you plug the end of the 6-pin cable that fits into the PSU and not the actual 6-pin itself. Does that answer your question?
EDIT: PERIF refers to molex adaptation and that sort of thing if that's what you mean. The PSU should come with a plug that fits.
https://linustechtips.com/topic/634196-power-supply-peripheral/#findComment-8190984
Did you see the images, and I am asking what is the peripheral 1 labeled on the PSU?
https://linustechtips.com/topic/634196-power-supply-peripheral/#findComment-8191001
Just now, Imam Ali said:
Did you see the images, and I am asking what is the peripheral 1 labeledon the PSU?
Edited above
https://linustechtips.com/topic/634196-power-supply-peripheral/#findComment-8191006
Thank you ???
https://linustechtips.com/topic/634196-power-supply-peripheral/#findComment-8191047
