Hello LTT Forum
i need help, i plan to upgrade my video card but i don't know which video card is best for me, i just play mainly on cs:go and dota 2, but my main focus is on cs:go my average fps on cs is 130, but my maps are only dust 2 and mirage, i just want a videocard thats not too pricey that can play on the res of 1024x768 that has a stable fps any suggestions would help thank you!
CPU: Intel i5-3570 on stock cooler
MoBo: Asus P8H61-M LX R2.0
RAM: (2) 4 GB ddr3
Graphics Card: Zotac 630 Synergy Edition
https://linustechtips.com/topic/634072-need-help-planning-to-upgrade/
For playing CS:GO at 1024x768, the IGP built into the i5-3570 is probably better than the Zotac 630 - almost anything is better than the 630.
Get an AMD RX 460 or 470.
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
6 minutes ago, roughavoc said:
Better off fixing your formatting, couldn't read the end of your post on dark mode.
Anyway, if you can easily afford it, grab a GTX 1060 / RX 480, whatever is cheaper
If cannot afford, GTX 750ti
If still, look used.
he plays at 1024x768
how can you recommend a $200 gpu
750ti will go a long way or 650ti etc on the used market
Photography / Finance / Gaming
Imagine if he thinks it would be a good idea to purchase a new monitor in 6 months time? What is this nonsense
He didn't say he was on a strict budget, he didn't mention budget whatsoever, so if he can afford a 1060 easily, get it as its the best price to performance and if he wants to up res, play another game or anything else it will be the best card to get.
thank you for the suggestions i was planning on 1060 or 1070 but its not available in our country, but i was thinking to buy a used gt 730 or 750ti graphics in the meantime, im planning to build a new pc in the end of the year ill ask again for suggestions for my next build xD
