[Problem] Plex web GUI not launching on FreeNas
Solved by 79wjd,
4 minutes ago, mider said:IP of FreeNas is xxx.xxx.xxx.50
IP of the Jail is xxx.xxx.xxx.51
In the installed tab it says "Service Status: ON"
when I click plexMediaServer disable security is checked and it says click Here to go open your PlexMediaServer
when i open the link the page doesn't load
Make sure that the plex jail is running. (try restarting it if it is)
Try unchecking VIMAGE (in the jail's advanced settings).
