Alright let's go through the process:
1. Was this an issue you had for a long time or something that randomly occurred one day?
2. Did you make changes to your computer recently?
3. Did you update any drivers recently?
4. Did you download some corn off some sketchy sites?
5. Did you try turning it off then turning it back on?
6. Are you able to connect to the internet via other devices without problem?
7. Have you tried resetting the router/ modem?
Blue screens eh? Did you try setting it to Wumbo?
https://linustechtips.com/topic/633084-internet-problems/#findComment-8171725
1. It appeared about 1 week ago.
2. I installed himachi but uninstalled it a couple hours later.
3. Only my Nvidia graphics driver.
4. Last time was about 2 months.
5. Yes, Every day.
6. My laptop, tablet, tv, ps4, xbox and phone have had no problems.
7. Yes, I reset my network switch and also my modem numerous times.
https://linustechtips.com/topic/633084-internet-problems/#findComment-8171759
3 minutes ago, onlybuilt4cubanxlinx said:
When I download large files or install games from Steam my internet gets knocked out. It like overloads and boots me off every time.
How does steam shutdown your computer for you? What do you mean by overloads?
https://linustechtips.com/topic/633084-internet-problems/#findComment-8171853
6 minutes ago, Damocles said:
That teredo tunneling service, some people reported having it conflict with it enabled. Since it's grayed out, it shouldn't cause any issues to disable it
Uninstalled it(since their was no option to disable it)
Didn't fix anything.
https://linustechtips.com/topic/633084-internet-problems/#findComment-8171898
Would it hurt? I know for a fact a bad cable can be a contributing factor to a random failure over time
Its currently 00:46 in the netherlands.
i'l let you know in the morning.
i'l report back on this post.
see you in about 10-14 hours
https://linustechtips.com/topic/633084-internet-problems/#findComment-8172031
