Convertible Ultrabook for Light Gaming
Canoas
I posted a similar topic on mobile devices but no one has any suggestions, so I'm trying my luck here. My current laptop is dying so I need something to replace it, and am looking for a convertible ultrabook. I will only do some light gaming on it, like LoL, L4D2 or SC2, so I don't need a graphics card as an intel HD 4400 is enough for it.
Anyway, what I'm looking for would be something like this:
Covertible Laptop
i5 Haswell CPU
Intel HD 4400
14-15.6" 1600x900 touch screen
6GB Ram
500 GB HDD
5h battery life on normal usage
2 Kg
less than 1000€
These would be the minimal requirements that I would accept. I have found laptops close to this, but none that actually fulfill those requirements:
Ideapad Yoga 13 - Only has 13" and a 3rd generation CPU
Inspiron 14 7000 - This one would be absolutely perfect if it were convertible
So yeah, if anyone knows of a computer that fits or is close to this then I'd very much apprecitate if you post it.
Why not an AMD A10? It's a true quad core and it can be had in somewhat thin computers with touchscreens, like the HP ENVY 15.
Main Rig: CPU: AMD Ryzen 7 5800X | RAM: 32GB (2x16GB) KLEVV CRAS XR RGB DDR4-3600 | Motherboard: Gigabyte B550I AORUS PRO AX | Storage: 512GB SKHynix PC401, 1TB Samsung 970 EVO Plus, 2x Micron 1100 256GB SATA SSDs | GPU: EVGA RTX 3080 FTW3 Ultra 10GB | Cooling: ThermalTake Floe 280mm w/ be quiet! Pure Wings 3 | Case: Sliger SM580 (Black) | PSU: Lian Li SP 850W
Server: CPU: AMD Ryzen 3 3100 | RAM: 32GB (2x16GB) Crucial DDR4 Pro | Motherboard: ASUS PRIME B550-PLUS AC-HES | Storage: 128GB Samsung PM961, 4TB Seagate IronWolf | GPU: AMD FirePro WX 3100 | Cooling: EK-AIO Elite 360 D-RGB | Case: Corsair 5000D Airflow (White) | PSU: Seasonic Focus GM-850
Miscellaneous: Dell Optiplex 7060 Micro (i5-8500T/16GB/512GB), Lenovo ThinkCentre M715q Tiny (R5 2400GE/16GB/256GB), Dell Optiplex 7040 SFF (i5-6400/8GB/128GB)
If AMD can match intel's haswell in terms of power consumption as well as having a comparable integrated graphics solution then I don't mind AMD at all. The only thing I care about is the performance, as long as it matches the specs I posted then I'm completely OK with it.
The A10's graphics are WAY better than haswell's but the battery life is probably not comparable.
I don't think you're going to find an ultrabook that has all that so you're going to have to either settle for a ultrabook that compromises in some areas or get a ultra slim laptop.
Mein Führer... I CAN WALK !!
If it can hold for 5h on normal usage then it's perfect for what I need. I'll even settle for 4h.
I'm very much ok with compromizing, that's why I asked for laptops close to those specs. Ultra slim laptops can't be used as a tablet.
They do have touch screen ultra slim laptops they just aren't convertible.
I don't really care what you call the laptop as long as it has the features I need. Ultra-slim, ultra-book, ultra-mobile, they're all just some shitty marketing denominations.
This one has auto switching graphics so the battery life should be decent. http://www.newegg.com/Product/Product.aspx?Item=N82E16834131487
But that's not convertible. The reason why I'm looking for a convertible laptop is so I can actually use it as a tablet, but if it can't be used as a tablet then in my opinion a touchscreens adds absolutely nothing to a laptop and I'd rather not have it.
So, since I wasn't finding anything similar to what I wanted I started looking at the upcoming laptops.. And WOW, the  ideapad yoga 2 pro looks absolutely amazing. I guess I'll have to survive with my current laptop for a while longer.
Why not wait for the Zenbook Infinity? I know it isn't a convertible and it will probably be over your budget (still no prices released for it) but I think it might have Iris5100 instead of HD4000/44000 (but it's going to run a higher native resolution, great for general use but negatively impacts gaming performance)
It doesn't really fit my needs. If it's not convertible then I have no need for a touchscreen, quite honestly it just looks incredibly combersome to use one, and the screen is too small. For 1000€ I can get a 1080p 15" with an haswell i7 and a graphics card, the only reason I would settle for a smaller screen and integrated graphics was just for the tablet mode.
It doesn't really fit my needs. If it's not convertible then I have no need for a touchscreen, quite honestly it just looks incredibly combersome to use one, and the screen is too small not to mention it will defintiely be over my budget. For 1000€ I can get a 1080p 15" with an haswell i7 and a graphics card, the only reason I would settle for a smaller screen and integrated graphics was just for the tablet mode.
