I heard that dremels are a great tool for modding. Is there a specific kind that you have to get? Is this one sufficient for a side panel window mod? https://www.amazon.com/WEN-2305-Rotary-Tool-Shaft/dp/B003BYRFH8/ref=sr_1_3?s=power-hand-tools&ie=UTF8&qid=1469380958&sr=1-3&keywords=dremel
I am planning to make a side panel window on a Corsair 200R and paint it.
Thanks!
https://linustechtips.com/topic/631786-tools-for-modding/
It should be okay. I used a jigsaw to cut the window out and a dremel to smooth out the rounded edges.
I would buy a 20 pack of cutting discs (not reinforced) since they're cheap and you'll be going through them alarmingly quick.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/631786-tools-for-modding/#findComment-8157360
Thanks, I'm not exactly sure if I'm going to be modding the case, however If I do, I will take your advice.
Thanks! :)
https://linustechtips.com/topic/631786-tools-for-modding/#findComment-8157430
The better question to ask when adding a window is: Do I want screws or double-sided tape for the window? I use tape since it creates a nice seal around the window for dust.
https://linustechtips.com/topic/631786-tools-for-modding/#findComment-8157497
