Hi, I need help on my PC. When I switched on the power supply, for 1 second all the lights and fan will turn on and off again. Then if I press power on, on my computer it will boot normally and ok. Is there something wrong with my PC? Thanks in advance.
Intel i7 2700k
Gigabyte h77 ds3h motherboard
MSI GTX 950 2g gaming (new)
2 x 4gb Hyper x RAM
Intel 540 SSD 120gb
Seagate barracuda 500gb
Corsair VS650 power supply
Some LED light and a scythe katana 3 CPU cooler
https://linustechtips.com/topic/631611-need-help-please/
1 hour ago, Samson_ST said:
the problem could be a shortage. check the wattage/volts on the power supply and then on the motherboard, storage, grapics card. if there is a difference of watts/volts between the connections, that could be the problem.
 you are saying that the psu is not supplying enough power? the psu is newly bought. tnx
https://linustechtips.com/topic/631611-need-help-please/#findComment-8155700
It may be normal, but I'd check if my front panel connections are properly connected if strange things like this happens. Make sure you dont plug in hdd led to pwr or reset or anything like that as that could explain the strange power cycle.
Blue screens eh? Did you try setting it to Wumbo?
https://linustechtips.com/topic/631611-need-help-please/#findComment-8156932
