I want to use the EVGA GTX 1080 graphics card in this build, and I need help to see if everything is compatible and will fit in my tower. willing to spend up to $1700 for this build. Any help will be appreciated.
This is my current build http://pcpartpicker.com/list/gkqskT
https://linustechtips.com/topic/631540-new-pc-builder-need-help-with-current-build/
You have incompatible parts.
The motherboard is eATX while the case only supports ATX/mATX.
I edited the build. Since youre running a single GPU you don't need Extended ATX anyway. Changed it to a very well respected ATX model, I also gave it a SuperNova G2 650w PSU since theyre some of the best on a market. It says that the case doesnt support 2x120mm rads but I think that is incorrect. Id advise that you search around a little bit to see if its true, if so I would suggest a different case since 2x120mm is the smalled AIO that will be better than a decent air cooler.
http://pcpartpicker.com/list/23BmgL
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
