About a 10 days ago, I installed Linux and handbrake on an old i5 laptop and I started transcoding video on it... a log of video, so it's running 24/7, at 100% load on the 4 threads. It's stable around 80 to 82.5 degree.
I can easily feed it more job for at least a month, but I am curious to see if it can keep up with the work load for an extended period of time, considering that laptop are not designed to run like that, at least it's not overheating.
How long do you think it can last ?
https://linustechtips.com/topic/630833-how-long-will-it-run/
Until something melts and sets on fire.
CPU i7 6800k @ 4GHz, 1.255v
Cooler Scythe FUMA 2
Motherboard ASUS X99 ROG
RAM 16GB Corsair Vengeance LPX DDR4
GPU EVGA GTX 1070 FTW (+100MHz core, +200MHz memory)
Storage Samsung 970 EVO 1TB, 500GB WD Blue SSD, 1TB WD Blue HDD
PSU EVGA 650G2
Case Phanteks P400S TG + 3x NZXT Aer 2 RGB Fans + NZXT Hue 2
Monitors Acer CB271HU, Dell S2440L
OS Windows 10
PCPartPicker Link https://pcpartpicker.com/user/MiniManchu/saved/cHnWZL
https://linustechtips.com/topic/630833-how-long-will-it-run/#findComment-8148196
