WHile I have finally gotten around to overclocking my cpu and gpu with great results, I feel the CPU block I have might not be used to its full potential. Course this could be me being too worried about a few degrees. How ever my test had very very differing temps when I was using aida 64. It was all over the place and never really got me a good average number. So is it my block not having a good mounting, or maybe its time for a new block?
CPU: 5900X   MOBO: MSI Tomahawk x570
MEM: G.Skill 32gb (2 x 16gb) 3600
GPU: Asus tuf oc 3080
May add the other bits of my system later on
https://linustechtips.com/topic/629452-alphacool-cpu-block-mounting-issues/
May I ask what temperatures are you getting?
Use HWmonitor, and see what was max temperature after 30min running stress test.
If it's below 60°C, you don't have to worry about anything.
I'm just guessing here: Maybe temps are all over the place because water comes and water goes? So when pump pushes water, it will come cold one so temps will drop a bit and then slowly rise again and drop a bit etc. Not sure if that's how it works, but it seems kinda logical to me.
But I could be 100% wrong on this one, since pump is running pretty fast and water is moving all the time.
I'm realy interested in your temps :)
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
My temps were in the mid 60s, mind you mt i5 4690K was OCed to 4.5 with a 1.25V. And I was using AIDA 64 to test it for 30 minutes. I did get spikes into the low 70s.
Is your GPU also in the loop?
Did you stress test just CPU or also cache and FPU?
FPU and cache seems to cause much heat on CPU for some reason.
WD My Cloud 4TB
I think I tested the cache and fpu with the adia64 stress test. And yes, my 980 Ti is in my loop as well.
