So no one at my work happens to be very audio-tech-savy, and we are looking at getting a new set-up for our conference rooms, mostly the microphone side.
Current ideas we have are:
  • Drop-down Mics: 4-6 Mics per room, hanging from the ceiling, placed in a quadrant/sextant of the room.
  • Extension Mics: Add an additional 2 mics per room of the same brand we already use
  • Put one or two Blue Snowball Mics in each room, one at each end.
But the problem is, our Avaya Phone system to dial into the meeting can only take 2 mics per phone. If we get two of the phones in the same room, we get feedback. So we need some sort of splitter to condense multiple mics into single lines.
Because none of us know a lot about audio, we don't know if we need something as simple as a 3.5mm splitter or if we need a soundboard like this, or if either of those would even work with the Avaya Phone System/GoToMeeting.
We don't need anything fancy, just something that takes in 3.5mm (or a cheap converter to make 3.5mm work with it) and outputs to 3.5mm (or is able to be converted)
Price really isn't a problem, as we are just getting ideas out for the upgrade.
EDIT:
Also, what about this?
GIGABYTE Z97MX-G516GB DDR3 | I5 4690k @ 4.4ghz | 1TB SSHD, 500GB HDD, 128GB SSD | GTX 1070 8GB | Corsair Graphite 230 | EVGA 650W | Hyper 212 EVO
Cinebench R15: 636(all cores), 127FPS
https://linustechtips.com/topic/628452-gotomeeting-audio-solution/
How come you require the extra mics?
At my last work place, We used the same phone in a large boardroom never had any issues with picking up someones voice?
Though the extra mics would of helped :)
Gaming Rig:
CPU: AMD Ryzen 3600X @ 4.1GHz All Cores - Ram: 16GB Corsair VENGEANCE - GPU: 5600XT MSI Gaming X - Storage: Samsung EVO 840 250GB - 2TB Seagate Drive OS: Win10
HTPC Rig:
CPU: i5 6400 - Ram: 16GB - GPU: 970 GTX - Storage: 120 Kingston SSD & 2x 1TB Seagate Drive OS: Win10
The people who are using the rooms are claiming the mics don't pick enough people up. We haven't tested it ourselves, but the people using them tend to be tech savy enough to know what their problems are. Key word: tend.
I'm just doing the busy work to see what solutions would cost for any of the problems. Right now I'm stuck on the audio side.
Oh right, We had the same thing about them claiming it's not working correctly. Till we tested it ourselves and showed them it was working fine.
Maybe a case of testing it for yourself and moving the mics to get the best coverage?
Sorry I'm not be a great help on this topic, Just giving you ideas hopefully :)
Gaming Rig:
HTPC Rig:
No problem at all! We were planning on testing it in the near future as well, hopefully that is the problem.
