Hi, I am using an app called "battery life" for iphone and it always shows different amount of current battery capacity. One minute it shows 99% and the other 98% or 97% then 99% again. So I am asking is this app legit with this? ?
CPU i5-4460, Motherboard MSI Z97 GAMING 3, RAM 16 GB HyperX Fury Blue, GPU MSI GTX 970 GAMING, Case CONNECT IT Battle Case, Storage 1TB HDD, PSU S12II-520, Monitor iiyama ProLite X2483HSU-B2, Cooling SilentiumPC Fera 2, OS Windows 7 Professional
https://linustechtips.com/topic/628312-battery-life-apps/
What exactly do you need a battery life app for?
https://linustechtips.com/topic/628312-battery-life-apps/#findComment-8105147
I am using it to see my cycles, temperature and current maximum capacity of the battery compared to the design capacity.
https://linustechtips.com/topic/628312-battery-life-apps/#findComment-8105864
oh I see, never bothered to look :D
https://linustechtips.com/topic/628312-battery-life-apps/#findComment-8106096
I care about it a lot :D My current battery capacity is 1653 mAh but sometimes it changes to 1670 mAh so I don't think it's trustable. It's hard to see how the capacity decreases and time you can use your phone is decreasing either
https://linustechtips.com/topic/628312-battery-life-apps/#findComment-8106542
do you really notice the length of usable time?
https://linustechtips.com/topic/628312-battery-life-apps/#findComment-8107150
When it shows i have 99% of capacity I can use it for 8 hours and when I have 98% of capacity I can use it just for 7 hours.
https://linustechtips.com/topic/628312-battery-life-apps/#findComment-8107526
but how can you know that during those 8 hours its getting the exactly same usage, screen on time, same  apps etc
https://linustechtips.com/topic/628312-battery-life-apps/#findComment-8107696
The app shows it
https://linustechtips.com/topic/628312-battery-life-apps/#findComment-8107780
The app shows it
no I understand that
but unless you do a controlled test, its going to be hard to work out, i mean maybe one day you play a game for an extra 5 minutes and your phone loses an extra half our of battery life etc
every single thing you do effects the life
https://linustechtips.com/topic/628312-battery-life-apps/#findComment-8107820
Yes I understand, but if I had 100 % of capacity I can afford to play an extra 5 minutes.
https://linustechtips.com/topic/628312-battery-life-apps/#findComment-8108167
Now I checked my battery health using iBackupBot and it showed that I have capacity 1700 mAh out of 1690 mAh and I think its wrong. Every one has after 100+ cycles capacity 99%+ but I have after 60 cycles only 98 %. What did I do wrong?
https://linustechtips.com/topic/628312-battery-life-apps/#findComment-8125032
