Hello, so , like i said in the title, I'm going to build a pc and need some suggestions, my goal is to be able to play basically everything in 1080p at +60fps, i was thinking about this:
CPU: i5 4690 (no K, i know, but i don't think I'm going to want to overclock in the future)
GPU: AMD RX 480
RAM: Kingston HyperX Fury 8GB DDR3 1600
Case: NOX MC HUMMER 3.0
HDD: Seagate Barracuda 7200.14 1TB SATA3
Motherboard: No idea at all
Power Supply: Again, no idea at all
SSD: None
My price range is around 700-800 €, I know the RX 480 is maybe a bit overkill, but i don't want to have to change my graphics card in 2-3 years so, any suggestions/tips you have, make sure to comment.
Thanks for helping and sorry if i had any error, english is not my first language.
Edited by Nexas
https://linustechtips.com/topic/627135-building-my-first-pc/
GPU: AMD RX 480
SSD: None
Why not go newer with a skylake i5?
My Main PC:
CPUi5 3570k CPU Cooler: Cooler Master Hyper T4 Motherboard: Asus p8z77-v pro  RAM: Crucial Balistic 2x4gb  GPU: Two PNY GTX 680's in SLI Case: Some rando Antec one  PSU: Thermaltake 1000w  Display: HP Elite Display 321i 23''  Storage: Samsung 840 Evo 128gb, Seagate Barracuda 1tb
https://linustechtips.com/topic/627135-building-my-first-pc/#findComment-8090893
6 minutes ago, Nexas said:
Don't know, most ones i've seen perform not much better while there is a 40-60€ difference in price
Hows this? http://uk.pcpartpicker.com/list/99ZKBP
My Main PC:
https://linustechtips.com/topic/627135-building-my-first-pc/#findComment-8090944
you dont need skylake, and the 480 is not over kill.
CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
https://linustechtips.com/topic/627135-building-my-first-pc/#findComment-8090945
If his budget supports it, why not?
My Main PC:
https://linustechtips.com/topic/627135-building-my-first-pc/#findComment-8090953
it is not much better if anything i would say to get an i7
https://linustechtips.com/topic/627135-building-my-first-pc/#findComment-8090959
Well he doesn't need an i7
My Main PC:
https://linustechtips.com/topic/627135-building-my-first-pc/#findComment-8090966
ok then,i would get an ssd before that still
https://linustechtips.com/topic/627135-building-my-first-pc/#findComment-8090974
GPU: AMD RX 480
SSD: None
this is a good mobo for cheap http://www.newegg.com/Product/Product.aspx?Item=N82E16813157369&cm_re=LGA_1150-_-13-157-369-_-Product
https://linustechtips.com/topic/627135-building-my-first-pc/#findComment-8090977
GPU: AMD RX 480
SSD: None
This is a nice reliable power supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817438028
https://linustechtips.com/topic/627135-building-my-first-pc/#findComment-8090985
http://uk.pcpartpicker.com/user/PenguinJuice/saved/#view=RQj8TW
A bit more expensive (can remove SSD). I personally think PSU and SSD are a really good investment because they can be used in future builds easily. I also think it is better to spend about 40 more euros to be able to afford a motherboard that allows overclocking and a cpu that allows it. You are right that the 4690k is similar to the i5 skylake CPUs but skylake is still better and its only a tiny bit more expensive. Not to mention because of you having this motherboard you can upgrade your CPU easier in the future depending on if you want to.
https://linustechtips.com/topic/627135-building-my-first-pc/#findComment-8091024
Thank you all guys for helping, but I think I'm going to keep with the i5 4690 rather than a skylake, it performs better than a 6600 and it's  cheaper, and for the SSD, (i think this is true, but not sure) it doesn't improve in.game performance. For the motherboard I think i'll keep this one as suggested http://www.newegg.com/Product/Product.aspx?Item=N82E16813157369&cm_re=LGA_1150-_-13-157-369-_-Product however, the power supply suggested is ready for SLI , which I'm most likely never going to do) and maybe it's too much power for what i need, so if you have any suggestions for a PSU you know what to do.
https://linustechtips.com/topic/627135-building-my-first-pc/#findComment-8091357
This is false. Also, skylake offers faster DDR4 memory.
Do you have a particular online store where you're buying your parts, maybe I could browse through there.
  • Quote people's post else they won't know you replied.
Crapware | 4670k | Hyper212X | GSkill RipjawsX 16GB | Sapphire R9 280x VaporX | 840EVO 120GB | 1TB BLACK + BLUE
Logitech G102 | Corsair K70 MX Brown | HyperX Cloud
https://linustechtips.com/topic/627135-building-my-first-pc/#findComment-8092465
Yes i do, http://www.pccomponentes.com/ (it's a spanish website, so maybe you'll have a bit of a problem, if anything, ask me.)
And for the skylale thing im basing on this: http://cpuboss.com/cpus/Intel-Core-i5-6600-vs-Intel-Core-i5-4690 maybe i didn't understand it right but the only better thing in the 6600 is the integrated graphics which i dont need
https://linustechtips.com/topic/627135-building-my-first-pc/#findComment-8093281
I did have a few problems with the site but google translate delivered.
€489.80 + €49.95 Nox Hummer MC Case + €269.00 Sapphire Radeon RX 480 8GB = €808.75 All in all
Alternate case: €41 Aerocool Aero 500, I've seen some good reviews of this
*Consider waiting for the aftermarket variants of the 480
*Get an i5 6500 for €30 less if you're short on budget, it'll make it around €780
https://linustechtips.com/topic/627135-building-my-first-pc/#findComment-8093430
After looking at what you posted i got to this:
I decided to go for a bit better motherboard cause i have enough money and with that RAM cause the case has a window on the side and i want it to look cool xD (Also i forgot to add the SSD) Thanks for helping and if you have any final suggestions leave them below and if not I'll close this post. Thanks again for helping.Sin título.png
https://linustechtips.com/topic/627135-building-my-first-pc/#findComment-8093489
