10 minutes ago, HazeTheBeater said:
Your case has a 240mm spot on the top, So yeah you can fit the radiator in there but you needa check if the AIO Supports LGA 1151 (Your socket)
The radiator is 280mm so where should I put it? Should I just get a 240mm instead so I can put it on top?
https://linustechtips.com/topic/626594-aio-cooler-help/#findComment-8084953
On 7/14/2016 at 6:15 PM, darkninja8888 said:
Hi I was wondering if my AIO cooler would fit my case (both rad and enough tubing to get to the cpu socket). I'm very new to liquid cooling. Here is my build http://pcpartpicker.com/list/J8GNQV. Thanks!
Lot folks don't seem to realize that you can filter completed builds for part combinations on PC Part Picker. So, to answer your question I present this list of builds:
http://pcpartpicker.com/builds/#h=4,328&e=1186
Uses the h100 GTX and the same case. That is a fairly standard AIO cooler. I belive it'd be a 240mm - Same size I run (build in signature)
https://linustechtips.com/topic/626594-aio-cooler-help/#findComment-8092262
