So after a failed attempt at rooting, my phone is stuck in a bootloop. I'm not an expert but I'll state what I know:
  • I do have it backed up with titanium backup however i dont know how to access it on my phone but I copied the folder on my pc
  • My recovery OS thing is TWRP
  • I have tried to wipe my phone using TWRP and then reinstalling the firmware via ODIN but this happens: <ID:0/005> Added!!
    <OSM> Enter CS for MD5..
    <OSM> Check MD5.. Do not unplug the cable..
    <OSM> Please wait..
    <OSM> G925TUVU2COF6_G925TTMB2COF6_G925TUVU2COF6_HOME.tar.md5 is valid.
    <OSM> Checking MD5 finished Sucessfully..
    <OSM> Leave CS..
    <ID:0/005> Odin engine v(ID:3.1005)..
    <ID:0/005> File analysis..
    <ID:0/005> SetupConnection..
    <ID:0/005> Initialzation..
    <ID:0/005> Get PIT for mapping..
    <ID:0/005> Firmware update start..
    <ID:0/005> SingleDownload.
    <ID:0/005> sboot.bin
    <ID:0/005> NAND Write Start!!
    <ID:0/005> FAIL!
    <ID:0/005>
    <ID:0/005> Complete(Write) operation failed.
    <OSM> All threads completed. (succeed 0 / failed 1)
So any ideas?
https://linustechtips.com/topic/626247-galaxy-s6-edge-rooting-problem/
19 hours ago, TaylorSwiftOrNon said:
Have you enabled dev mode for usb?
Yes I have. I also forgot to mention this may be the problem:
When I try to reboot into any of the options, my phone will freeze. I then have to hold down volume down and the power button to reboot the phone back into TWRP. I can however access Download mode.
  • 2 weeks later...
