Using a BT Hub 5 for a repeater
ChevbeeHD
Hi,  I am currently on virgin and have range issues (I am aware of range extenders)  but I have spare BT Hub 5  and would like to use it as a range extender / repeater...  Thing is I'm not sure how... If you know how this would work comment down below... All responses will be appreciated...
You will have to run a cable from the 1st router LAN port to the 2nd router LAN port and put the 2nd router in a "ap/access point mode" or disable NAT, DHCP, DNS eta.
What are you looking for?
