help, give me some advice
Go to solution Solved by lmao234,
Not sure about fans but NZXT are the sexiest cases eva! Argue with that.
so i want to buy a new case for my components, if it is possible i want a case that allows 2x 120mm fans in the front, 2x 140mm on the top, 1x 140mm in the back, and a window in the case.
$100-200 for case
AND HAS TO BE SEXY
Cpu: I7-3770k @4.2GHz Mobo: Gigabyte Z77-UP4TH Ram: Kingston Hyper x 16GB GPU: Gigabyte 7950
PSU: Corsair TX 850  HDD: WD RED 2TB Cooling: H100i Case: NZXT 630
https://linustechtips.com/topic/62510-help-give-me-some-advice/
Fractal Midi R2, or Fractal R4.
One is for optimal airflow, one is for silence, pick which you want.
They are pretty much the go to cases at this point for any purpose, specially the R4, its excellent.
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/62510-help-give-me-some-advice/#findComment-854031
Corsair Obsidian 750D/ 350D
Cooler Master Cosmos SE
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/62510-help-give-me-some-advice/#findComment-855871
AMD FX 6300 | ASUS M5A97 R2.0 ATX AM3+ | HITACHI ULTRASTAR 1TB 7200RPM HDD | XFX RADEON HD 7950 3GB | 8GB DDR3-1600 MUSHKIN BLACKLINE | OCZ ZT 550W 80+ BRONZE PSU | ZALMAN Z5 PLUS CASE | LITE-ON iHDS118-04 DVD/CD DRIVE | BENQ GW2255 21.5" MONITOR
https://linustechtips.com/topic/62510-help-give-me-some-advice/#findComment-856047
Im going to get the new phantom 530 matte black!!!
THANKS GUYS!!!
https://linustechtips.com/topic/62510-help-give-me-some-advice/#findComment-863127
