2nd gpu wattman help
Go to solution Solved by LooneyJuice,
I could be wrong, but this used to happen all the time due to ULPS (Ultra Low Power State) with Xfire. It essentially switches off the second GPU completely when not under load. One thing you could try is run Unigine Heaven in window and go back to the Wattman screen while it's running to see if the sliders activate. Do this for a couple of games too. If it's still dead, check connections, reseat GPU, and if all else fails, place it in the first PCIe slot on its own to test.
well it says your frequency is 0 mhz max but I have no idea why or how you have it that way but I THINK that is why it isn't taking power
Build Name:
Anton
CPU: I7 4790K
GPU: ZOTAC RTX 2060 SUPER AMP EXTREME
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
CASE: COOLER MASTER N300
PSU: THERMALTAKE 600 WATT
STORAGE: TOTAL 6.5TB, 512GB SAMSUNG 850 PRO BOOT DRIVE, 2TB HDD 1, 2TB HDD 2, 2TB WESTERN DIGITAL USB 3.0 BACKUP DRIVE
- CRACK!
https://linustechtips.com/topic/624269-2nd-gpu-wattman-help/#findComment-8057229
OS: W10 | MB: ASUS Sabertooth P67 | CPU: i7 2600k @ 4.6 | RAM: 2x8GB Corsair Vengeance 1600mhz | GPU: x2 MSI GTX 980 Gaming 4G | Storage: x2 WD CB 1TB, x1 WD CB 500GB | PSU: Corsair RM850x | Spare a moment for Night Theme Users:
I'm an erudite cave-dwelling Troglodyte
I frequent LinusTechTips past midnight
Dark backgrounds I crave
For my sun-seared red gaze
I'll molest you if you don't form your text right
https://linustechtips.com/topic/624269-2nd-gpu-wattman-help/#findComment-8058220
