Help! (Heatsink installation"
14 minutes ago, Hahzi said:
I have a amd heatsink and processor basically the hinges wont connect with the black plastic parts on my mobo I can get one down then the other cant and vise versa.
Are you sure the cooler you are using is compatible with the socket type? What cooler is it?
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
11 hours ago, Zyndo said:
because applying a bunch of pressure in and around the CPU socket has never gone poorly for anyone in the past.... GL!
Apparently you haven't ever built PC. You'd be surprised how much force components can take and sometimes need for installation.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
The crunch when pushing down the lever is the worst.
Yeah. And when you realize that you'll need flat head screwdriver to connect PSU cables.
Thats annoying not scary
It falls in line with screws that are underneath something else
Its scary when you think that wires could be kinked or cut if something slips. They are all things that scare first time and then its all fine.
Havent had that. Maybe because my early systems had non modular psus cable management holes etc meaning most of them were easy to access
I've not built a TON of PC's, you're right. But I've built a few. Why you gotta be so serious? I was just messing with him lol. If it worked for him, then great.
