CPU Problem
Solved by Jumper118,
4 minutes ago, Tehepic said:It only shows one and does that mean its only using one?? I am using home Windows 10
Here is the picture of CPUZ
If you are using home windows then it can only see one cpu. Like I said you need windows pro to see 2 cpus. I use Windows 7 pro on all my systems and boths cpus show up.
Xxu ·
Posted in Servers, NAS, and Home Lab0 -
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Posted in Servers, NAS, and Home Lab3 -
Sveeno ·
Posted in LTT Releases8
play_circle_filled
Latest From ShortCircuit:
