I recently ordered part for my computer build and in it i had an optical drive. i want to know if it comes with cables to hook it up to the motherboard. i have never installed one of these so please advice would be appreciated :) heres my build: http://pcpartpicker.com/list/fZ6nnn
https://linustechtips.com/topic/622564-does-this-come-with-cables-advice/
SATA power cables will come with the PSU and SATA data cables will come with the motherboard.
The Optical drive likely won't come with any cables. You may need to buy another SATA data cable if your board doesn't come with enough.
do you know if there will be a designated spot on the motherboard for the optical drive?
