3 minutes ago, mathmeister said:
I have two builds, the ITX one has no SSD and a worse CPU but if they were the same and I had space limitations on my desk, is the ITX worth going for?
ATX: http://pcpartpicker.com/list/4vNXHN
ITX: http://pcpartpicker.com/list/xXNXHN
personally would go for the ATX, ITX is too limited in terms of upgrades and cooling.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/622435-atx-vs-itx-build/#findComment-8026707
ATX, but if You don't have the space, the ITX build seems very good also, of course it still needs a SSD
CPU: Intel i7 5820K CPU @ 4,3 GHz CPU Cooler: Noctua NH-D15 Mobo: ASUS X99-A/USB-3.1 Ram: Kingston HyperX Fury DIMM Kit 16GB, DDR4-2400 Optical: LG GH24NS DVD Burner Optical: BD Reader SSD: Samsung SSD 850 Pro 256 GB SATA 6GB's PSU: Seasonic X650 Video Card: ASUS STRIX GTX 970 Case: fractal design Define R5 black OS: Windows 10 64bit Monitor: Dell U2715H
https://linustechtips.com/topic/622435-atx-vs-itx-build/#findComment-8026721
You dont need an aftermarket CPU cooler since you won't be overclocking. Stock is fine. The Evolv ITX has a crappy intake fan, so you would need to replace with dual 120 or 140mm (preferably 140mm) fans. Even better, get the Fractal Design Define Nano S like I have and you would only need to buy one more 140mm intake fan. I don't see why you cant get an SSD in your ITX build when your ATX build costs more. 240 - 256 GB SSDs can be had for about $80.
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/622435-atx-vs-itx-build/#findComment-8026748
That was just a mistake, the specs will be the same.
https://linustechtips.com/topic/622435-atx-vs-itx-build/#findComment-8026779
