9 minutes ago, BraveSaw said:
i have a r9 390 8gb version of msi but i want to know that my powerr suppy could power it or not it has a 6pin pcie connectors  and it is 650 watts and if not what is the least no. of pcie connectors are required to power it
You would need a 8 pin and a 6 pin to power the card and a 650W should work just fine.
| Ryzen 7 3700x | 16GB Vengance @ 3200 | MSI GTX 1070Ti Gaming |
| ADATA XPG SX8000NP 256GB Nvme SSD + WD Blue 500GB SSD | 4TB WD Blue |
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/622413-power-supply-issue/#findComment-8026465
What PSU is it? Not all 650W PSUs are created equal.
https://linustechtips.com/topic/622413-power-supply-issue/#findComment-8026473
we need to know more, more specifically, which model?
It's easy for a company to say it "my psu can handle 650w" but for how long? 1 minute? 1 second?! Will it fail when trying and might it pose a fire hazard??!?!?!
https://linustechtips.com/topic/622413-power-supply-issue/#findComment-8026500
32 minutes ago, BraveSaw said:
do i specifically need a 8+6 pin pcie connector can i run it on only on a single 6 pin connector or a single 8 pic connector..?
You will need a separate 8 and 6 pin (8 pin s usually a 6+2 pin).
     | Corsair RM650x |
| NZXT H200 White |
https://linustechtips.com/topic/622413-power-supply-issue/#findComment-8026889
What's the make of your power supply? That is more important that its wattage. A junk 1000W PSU would still take out your system.
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/622413-power-supply-issue/#findComment-8027010
