I ordered an Inwin 901 for my next build.
https://www.inwin-style.com/en/gaming-chassis/901
Today as i was plowing through the internet in search of good deals, i've finally settled on grabbing a Palit GTX 1070 Super Jetstream, however i have ran into concern for the issue in which i am not sure if the graphics card will actually fit or not.
Are there any Inwin901 owners here that can share your experience with the case?
I've looked through google and everywhere for the maximum GPU clearance of this case and the exact size of the Palit 1070 Super Jetstream but i am unable to dig up any concrete results.
https://linustechtips.com/topic/622322-need-help-with-gpu-clearance/
I'm worried about the width clearance of the cards, the maximum cpu tower cooling clearance is rated at 130mm but there is no info on the GPU clearance (is it the same?)
If that's the case, is this a definite no-go?
Board Size 285mm x 133mm
usually, yes. But since you insert a few millimets of the GPU into the the motherboard / the PCIe slot, you should be fine. But: Even though there usually is a little bit more space, consider the following: your GPU will block pretty much the entire vertical airflow in your case. Plus, if you pur pressure on the outside of the case (e.g. while carrying it) and they bent inwards, you will immediately touch your GPU.
"We cannot change the cards we're dealt - just how we play the hand" - R. Pausch
CPU: Ryzen 7 3700X , Cooler: BeQuiet Dark Rock 3 Motherboard: MSI B450 Mortar Titanium RAM: 16 GB Corsair LPX 3200 GPU: EVGA RTX2070 XC Storage: Adata 120GB SSD, SanDisk 1TB SDD, 2TB WD GreenHDD Case: Fractal Design Define Mini C PSU: EVGA Supernova 650GS Peripherals: Master Keys Pro S, Logitech G402 Audio: Schiit Fulla 2 + Sennheiser HD 650. Laptop: Asus Zenbook UX 302
Length is the one that usually matters the most since gpu's are just around same height and depth
''Daddy CumTits 2.0'' (pc):
CPU - Intel i7 8700k
GPU - Asus Strix 1080 8gb
RAM - 2x8gb Corsair Vengance
MOBO - Asus Prime Z370-p
PSU - Corsair RM750x
Sent a message to Inwin directly to ask...
I think i saw somewhere that someone managed to fit a 131mm without too much issue, but the extra 2mm might just be what makes or break as the power connectors will be pushing up against the side panel.
This sucks, i could get the 1070 Super Jetstream at a decent price but i might have to decide between the case or the card now.
P.S: Would a right angled 8 pin connector work? Not sure where the hell i can find one, but i could try.
