Need help Fixing Webcam
Solved by manikyath,
3 minutes ago, justRICHTOFEN said:so i found it, and i deleted the highlighted driver. But when i went to the website to re-download it, it said i was still running the latest drivers. I wasn't sure what i did, so i just deleted my whole web cam from my pc. Then un plugged it and plugged it back in. then i tried to install my drivers, yet again it said they were the latest ones. However the driver under the highlighted one wasn't there before i did that, and now my cam looks like it use to. So it seems my problem is solved but what exactly happend?
computers are magic, dont question ![]()
its just driver derpyness, sometimes stuff acts up and you have to fudge it to get it going again ![]()
