I'm looking to build a computer that can run games like overwatch at high or ultra
I've gotten most of the parts down but I need some recommendations for a storage device preferably an ssd and also I think the power supply I've chosen is a bit overkill what do you think
list of parts:
http://pcpartpicker.com/list/mf2tJV
Feel free to recommend other parts that you think might fair better in this rig
Thanks
Edit: I live in the Bay Area so prices are as indicated on sites I think
Edited by atom4399
https://linustechtips.com/topic/621881-need-help-with-build/
Looks pretty solid. I would say go for something like a Samsung SSD for a boot drive, and maybe a WD hard drive for mass storage (if you need a lot of space). The PSU is a little overkill, but a good choice if you are planning on getting another 1070 for SLI in the future.
Lenovo Ideapad 720s 14 inch ------ One day I'll have a desktop again...
https://linustechtips.com/topic/621881-need-help-with-build/#findComment-8020533
Thanks for the response
I've added a 500gb Samsung Evo and a WD Black 1tb so I will have enough space for most used applications in the ssd and took your recommendation for adding a hard drive for mass storage
I've also brought down the power supply to a lower wattage as I don't have plans for buying another card for sli in the future
Thank for the response. Really helped :3
https://linustechtips.com/topic/621881-need-help-with-build/#findComment-8020710
Yes looks good, but as you already said the PSU is overkill. 600W would be plenty for that rig.
CPU: Intel i7 5820K CPU @ 4,3 GHz CPU Cooler: Noctua NH-D15 Mobo: ASUS X99-A/USB-3.1 Ram: Kingston HyperX Fury DIMM Kit 16GB, DDR4-2400 Optical: LG GH24NS DVD Burner Optical: BD Reader SSD: Samsung SSD 850 Pro 256 GB SATA 6GB's PSU: Seasonic X650 Video Card: ASUS STRIX GTX 970 Case: fractal design Define R5 black OS: Windows 10 64bit Monitor: Dell U2715H
https://linustechtips.com/topic/621881-need-help-with-build/#findComment-8020735
I would get some faster ram. A 3000MHz kit would be my suggestion.
http://pcpartpicker.com/product/MYH48d/corsair-memory-cmk16gx4m2b3000c15
Also a 750W psu is more than fine for SLI. The EVGA G2 850W is currently at a good price though.
http://pcpartpicker.com/product/LCfp99/evga-power-supply-220g20850xr
https://linustechtips.com/topic/621881-need-help-with-build/#findComment-8020998
Thanks for the suggestion
the corsair sticks basically cost exactly the same so I'll change that if it means faster ram
thanks
https://linustechtips.com/topic/621881-need-help-with-build/#findComment-8022347
