Im in need of some slim fans for a radiator in a tight spot the ones i can find are
http://ca.pcpartpicker.com/product/MfQypg/gelid-solutions-case-fan-slim12uvblue
http://ca.pcpartpicker.com/product/smGj4D/silverstone-case-fan-fn123
http://ca.pcpartpicker.com/product/bwVBD3/thermaltake-case-fan-clf035pl12wta  In white red or blue leds
my question is what one is better the thermal take ones look the best but perform the worst on paper Also open to suggestions if you know of any i didnt list.
https://linustechtips.com/topic/620160-need-slim-fans-help/
55 minutes ago, BradH said:
-SNIP-
Slim fans aren't exactly ideal for rads as many aren't the best for pressure, there aren't that many options so it's slim pickings but the Coolermaster ones I've seen around tends to be one of the better pressure optimized ones:
http://www.coolermaster.com/cooling/case-fan/xtraflo-120-slim/
https://linustechtips.com/topic/620160-need-slim-fans-help/#findComment-8002912
ty and i know its not ideal but the case im going to be using is the caselabs bullet bh7 and its really only meant for a single 240 on the top but if you use slim fans you can squeeze in one on the front aswell
Edit: Mabey ill just wait to watercool until noctua finally realeases those 120x15 slim fans they have been bragging about for 2 years now
https://linustechtips.com/topic/620160-need-slim-fans-help/#findComment-8002983
