Hi need advice
Go to solution Solved by S4ujaRas4id,
5 minutes ago, Robin2236 said:
Hi, I'm planning to build a new rig. My previous pc died ( Actually the motherboard and Psu). Its an Amd A10 5800K with a Msi R9 380 gpu, 8gb of ram, 2x 1 T hdd and 600w aerocool psu. I was thinking of building a Fx setup. This are the items that I'm planning to buy.
Amd Fx 8350 black edition
Gigabyte 990FXA-UD3
Coolermaster Cm Hyper 212plus
Corsair RM750
I will be using my old case, an aerocool strike x advance, the single 8gb ddr3 memory,  msi R9 380, 2x 1T HDD and  a dvdr drive. I'm on tight budget so building an expensive Intel is not an option. And I have been using amd since the beginning  so I don't want to change that. Any advice?  What do you guys think. Ill be buying the psu first this week. Thanks.
How about an fx 8370 longer lasting and more power..
Gigabyte 990FXA-UD3
Corsair RM750
https://linustechtips.com/topic/620009-hi-need-advice/
Gigabyte 990FXA-UD3
Corsair RM750
https://linustechtips.com/topic/620009-hi-need-advice/#findComment-8001117
I did
10 minutes ago, Electronics Wizardy said:
Get a intel i5 6400 and a b150 mobo
Get a smaller 500w psu.
Use the stock i5 cooler.
I ws looking for that kind of fx. But sadly only tThe je fx8350 and 8370e are the only available ones
https://linustechtips.com/topic/620009-hi-need-advice/#findComment-8001164
