Need help
Solved by Guest,
Can't find any specs about the mobo to... However, they usually print the pin layout/functions on the board itself too. So if you but a new cast with the same kind of features on the front, you should be able to connect it. (or you might not get to use all the functions, which isn't that big of a problem anyways...)
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
play_circle_filled
Latest From ShortCircuit:
