Extention cable for phone Mic.
Go to solution Solved by ALwin,
1 hour ago, Abdul201588 said:
Isn't this an AUX cable? This is the one witch I have:
You need a TRRS extension cable, the one in the photo is TRS.
So I bought myself an external mic for my iPhone 5. Works great, only thing that annoys me is that the cable is too short. I've tried a standard extension but it doesn't seem to work.
Thanks.
https://linustechtips.com/topic/618758-extention-cable-for-phone-mic/
46 minutes ago, TriFlix Films said:
Google, "AUX extentions cable" lengths range from 6" to 12'
Homie... thats a male/female AUX cable. The one in your car is usually a male/male. Male means it has "prong" or an "outie" (lack of better words... a pen*s)
The female end is a hole... you do the math. What you need is that think in your hands. plug the microphone into the female end and the male end of the extension into the camera.
Unless your mic is XLR, then you may need to buy a new one. but 70%+ of "filmmakers" in the indie world use AUX which I assume you are as well.
Guide: DSLR or Video camera?, Guide: Film/Photo makers' useful resources, Guide: Lenses, a quick primer
Nikon D4, Nikon D800E, Fuji X-E2, Canon G16, Gopro Hero 3+, iPhone 5s. Hasselblad 500C/M, Sony PXW-FS7
ICT Consultant, Photographer, Video producer, Scuba diver and underwater explorer, Nature & humanitarian documentary producer
Alright! Thanks for the help. :) I will order one soon.
