I was playing gmod and suddenly my screen went to black and white strips in a vertical maner.
I waited for about 6 min then I turnd the pc off and back on
At first i didnt get any signal then suddenly a "broken" windows loggo apperd with wrong colors.
After 4 seconds the screen turned to black and then nothing more happend so I turned it back off.
What I can make of this is that my gpu has failed but im not that good at pc stuff
Systhem
Cpu i5
Gpu amd r9 270
Motherboard Asus somthing
Hdd sega 1tb
Ram dont know 8gb
https://linustechtips.com/topic/618577-pc-crashed-and-wont-start/
Unless you're on an old P67 board (or one of those GPU-less Xeon SKU's which you obviously don't!), you should be able to pull the GPU, hook up to the onboard graphics, and get it booted.
But yeah, I do suspect something's gone awry with the GPU.
This.
Either it overheated or it right away broke.
or your monitor broke, though the GPU is way more likely.
@Nord or quote me if you want me to reply back. I don't necessarily check back or subscribe to every topic.
Amdahls law > multicore CPU.
  • 3 weeks later...
