2 minutes ago, Albzter said:
I'm building a computer in the silent base 600 windowed case but how do I make it so I can install a graphics card that's longer than ~290mm? Gonna install the strix
1080.
Avoid Asus -
https://linustechtips.com/topic/617554-need-help-asap/#findComment-7972938
2 minutes ago, don_svetlio said:
Avoid Asus -
This. always check reviews before buying anything.
 CPU: Intel Core i5 6600K  Motherboard: Asus Z170-A  CPU Cooler: Corsair H110i GT  GPUGigabyte GTX 980 Xtreme  RAM:2x8gb HyperX Fury  SSD: 120gb A-Data  HDD: 1Tb WD Blue 7200RPM - 750gb Hitachi 2.5" HDD  PSU: EVGA SuperNova G1 650W  Case: Phanteks Enthoo Evolv ATX  Monitor: 27" AOC LED IPS x 2  Keyboard: Corsair Strafe RGB Silent  Mouse: Corsair Scimitar RGB
 HeadsetLogitech G430
https://linustechtips.com/topic/617554-need-help-asap/#findComment-7972950
Remove the HDD drive cages?
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/617554-need-help-asap/#findComment-7972977
Graphics Card 290mm / 400mm (w/o HDD cage)
Specs:
CPU: i5-6500 3.2 GHz Mobo: ASRock H110M-HDV RAM: Corsair Vengeance LPX 8GB 2133 MHz DDR4 GPU: GTX 1070 Founders Edition Storage: 120GB Sandisk Ultra II 1 TB WD HDD 7200 RPM PSU: Antec VP600P 600W Display: CrossOver 2795QHD 2560x1440 105 Hz OC OS: Windows 10 64 bit
https://linustechtips.com/topic/617554-need-help-asap/#findComment-7972984
Specs:
https://linustechtips.com/topic/617554-need-help-asap/#findComment-7972986
7 minutes ago, Albzter said:
Not helpful, anyone? please!
But it is, there are shorter options. As we said, avoid the strix. which opens you up to other options. But if your dead set on that card, case modding is about the only other option, but it being a decent size atx case how doesnt it fit? Or just remove the damn HDD cage...
https://linustechtips.com/topic/617554-need-help-asap/#findComment-7972987
If you can, remove the HDD cage, other than that, find a new card (i still suggest getting a new card, ive had bad experience with ASUS GPUs)
Winning an argument with a woman step by step
step one - talk to her
step two - fight with her for 2 hours even if you are really right
step three - admit that she is right for the sake of your safety
step four - realize that you have accomplished nothing and she still thinks you were wrong and now she thinks you are even more stupid
GTX1080ti, I5-4690k, ASUS Z97 PRO-GAMER, 8GB DDR3 1600mhz, Hyper 212 EVO, Tt view 31 RGB.
https://linustechtips.com/topic/617554-need-help-asap/#findComment-7972990
