Build for 2500 USD
Solved by WoodenMarker,
I'm going to the USA in February, so for now, every price and component can change depending on sales at the moment.
Regarding AMD, I chose the 780 because the AMD isn't out. Will look into them when they come out, but if they are anything like this series in the noise department, I won't get them.
I use After Effects and Premiere, also Photoshop, but mostly AE.
Check again later. Parts and prices change frequently.
Fyi, you need to quote a post or tag a member or else they won't get a notification you replied to them.
