i just bought an i7 5820k and i am currently cooling it with a H80i v2. my idle temps are are 42-45C and load(tested with BF4 on max settings) is 59-60c
I feel this temps are too high for using a water cooler and i dont think this is a hot running the chip. Did i lose the silicon lottery
*I used AI Suit to record temps because that is all i have
https://linustechtips.com/topic/616681-are-my-temps-ok/
No, perfectly fine temps.
120/140mm AIOs tend to give mediocre cooling performance for their price so it's normal to have those temps.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/616681-are-my-temps-ok/#findComment-7962748
X99 chips are quite hot running
what are your temps with p95, XTU or IntelBurnTest?
adjust fan profile
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/616681-are-my-temps-ok/#findComment-7962753
Is the chip OC'd at all?
CPU: I7 5960X @4612 MHZ/1.325Vcore | Cooler: Full custom loop | Mobo: Asus X-99A | GPU: 2 EVGA 980 TI Classifieds | RAM: G.Skill Trident Z 32 GBs 3200 MHZ | Storage: Samsung SM951 512 GB M.2 Drive, Mushkin Eco2 512 GB SSD, Muskin Chronos 480 GB SSD | PSU: Corsair HX 1000i | Case: Fractal define R5 | Monitor: LG 34UC87M-B
https://linustechtips.com/topic/616681-are-my-temps-ok/#findComment-7962759
adjust fan profile
i dont have any of those applications and i would know were to find them
i ran the fans on turbo mode which is about 1700 rpm( the fans a noctua)
https://linustechtips.com/topic/616681-are-my-temps-ok/#findComment-7962761
1 minute ago, sal said:
not yet because all a do is game with it currently but when i head of to college i will OC it for applications like auto cad and other 3D rendering software for engineering
Check corsair link and turn the pump speed up if it hasn't been already set at the max.
It's a tad bit warm for the 6 core.
https://linustechtips.com/topic/616681-are-my-temps-ok/#findComment-7962774
