Hi i recently upgraded my pc and now its getting quite some weird stuff going on in it. It sometimes doesnt post, but it boots and after it goes tru uefi safe boot it works again. When i boot up it gives me error ''qfan help EAcces violation. Today ive been getting (dont know the word for it) but nothing responds to anythign so its basicly frozen, but some apps still work, mainly ones that are open,but barely. IT happened 3 times tonight. 1st when opening doom 2nd and 3rd while in doom loading screen. Now i scratched one of my mobo's soldering points on the top side with my case, so can it be that?
''Daddy CumTits 2.0'' (pc):
CPU - Intel i7 8700k
GPU - Asus Strix 1080 8gb
RAM - 2x8gb Corsair Vengance
MOBO - Asus Prime Z370-p
PSU - Corsair RM750x
https://linustechtips.com/topic/615046-weird-stuff-going-on/
4 minutes ago, Flavortown2k16 said:
Mobo, psu and cpu
I'm pretty suspicious of the mobo. CPU issues would cause blue-screening, PSU issues would cause system instability and crashing. Considering that it has to start itself in safe-mode, I'd say that's a pretty clear indicator that the mobo is screwed.
https://linustechtips.com/topic/615046-weird-stuff-going-on/#findComment-7944782
Will ''broken'' mobo brake rest of the parts? I really cant afford to spend on another 990 board until next month.
https://linustechtips.com/topic/615046-weird-stuff-going-on/#findComment-7944783
Its not in safe mode like in windows. The mb has this safe boot thing that reverts setting back to normal if it fails to boot too many times if you screw underclock or something like that. And it starts normally like 80% of the time
https://linustechtips.com/topic/615046-weird-stuff-going-on/#findComment-7944798
I know. That's what I'm talking about. It's failing right at the bios level, so software is irrelevant.
https://linustechtips.com/topic/615046-weird-stuff-going-on/#findComment-7944805
Key, well ill get another mb next month and hopefully it will fix this
https://linustechtips.com/topic/615046-weird-stuff-going-on/#findComment-7944813
