Planning on making this mostly for video games as well as possibly some programming and light video editing/creation.  Here is what I've pieced together so far: http://pcpartpicker.com/list/zdKwPs I'm not hard set on the following.
Motherboard
Cooler
Case
PSU
Video card
I do have a drives that can be transplanted from my current system as well as my current video card.  Here is what is in my current system.
        Operating System
            Windows 10 Pro 64-bit
        CPU
            Intel Core i5 3570K @ 3.40GHz    44 °C
            Ivy Bridge 22nm Technology
         RAM
            16.0GB Dual-Channel DDR3 @ 655MHz (9-9-9-24)
          Motherboard
            ASUSTeK COMPUTER INC. P8Z77-V LX (LGA1155)    39 °C
         Graphics
            Panasonic-TV (1920x1080@60Hz)
            1023MB NVIDIA GeForce GTX 550 Ti (EVGA)    65 °C
         Storage
            2794GB Seagate ST33000651AS (SATA)    39 °C
            223GB Crucial_CT240M500SSD1 (SSD)
            2794GB Seagate ST33000651AS (SATA)    56 °C
            2794GB Seagate ST33000651AS (SATA)    53 °C
            1397GB Seagate ST1500DL003-9VT16L (SATA)    45 °C
         Optical Drives
            TSSTcorp CDDVDW SH-222BB
         Audio
            NVIDIA High Definition Audio
https://linustechtips.com/topic/613539-help-plan-my-build/
I see your point and that had crossed my mind.  However, I was thinking along the lines of getting away from the aircooled system i have moving towards watercooled and get onboard with the skylake series with some DDR4.  If I did opt to upgrade just the graphics card in my current system any recommendations?
https://linustechtips.com/topic/613539-help-plan-my-build/#findComment-7928189
What CPU did you choose? The 3570K (provided you overclock it above 4,5gHz) is still good enough for gaming and will not bottleneck higher-end cards.
What's your budget? What's your location?
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/613539-help-plan-my-build/#findComment-7928190
You can still fit a water cooler to your current i5 if your case takes one. Also DDR4 doesn't really make any difference over DDR3.
For a 1080p 60Hz monitor then the upcoming RX 480 looks like a good buy. If you plan to go to 1440p then a GTX 1070 would be ideal.
https://linustechtips.com/topic/613539-help-plan-my-build/#findComment-7928202
2 minutes ago, Mr_NightRyder said:
Question is can my current build handle the overclock mentioned above or would I need to look at other motherboard options?  I really like the idea of a 4.00+Ghz build
It is impossible to say whether you will get 4GHz on the i5 3570K as every cpu is different. I would suggest buying a good water cooler (NZXT X61/Corsair H110i GT etc) and giving it a try first. You can always transfer the new cooler to a new build if you are not satisfied with performance.
https://linustechtips.com/topic/613539-help-plan-my-build/#findComment-7928221
5 minutes ago, Mr_NightRyder said:
Good call that + a vid card will definitely save me a boatload of money and keep the wife happy :) ... as for the 1070 I also see a 1080 series is the added cost worth it to go to the 1080?
If you don't plan to game at 4K then not really.
https://linustechtips.com/topic/613539-help-plan-my-build/#findComment-7928235
14 minutes ago, Mr_NightRyder said:
I'm in the US as for my budget honestly I'd like to stay around $1000 if possible but am flexible probably up to about $1500.  From what I've read the skylake blows ivy bridge as well as Haswell out of the water.
motherboard is completely overkill :/
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($324.99 @ Newegg)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($114.99 @ Newegg)
Motherboard: Gigabyte GA-Z170X-GAMING 6 ATX LGA1151 Motherboard  ($137.49 @ Newegg)
Memory: G.Skill Ripjaws V Series 32GB (4 x 8GB) DDR4-2400 Memory  ($114.99 @ Newegg)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($154.79 @ OutletPC)
Video Card: Zotac GeForce GTX 1070 8GB AMP Edition Video Card  ($449.99 @ Amazon)
Case: Cooler Master MasterCase Pro 5 ATX Mid Tower Case  ($119.99 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($84.99 @ NCIX US)
Total: $1489.22
Generated by PCPartPicker 2016-06-19 15:40 EDT-0400
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/613539-help-plan-my-build/#findComment-7928240
The water cooled aspect leads me to another question.  How difficult is maintaining the water cooling?  I've always used air cooled systems but have always wanted to move to a water cooled solution.  Is there a special type of water you should use to prevent buildup/blockage or calcium?  Our water here in Florida quite frankly sucks.
https://linustechtips.com/topic/613539-help-plan-my-build/#findComment-7928257
Maintenance in watercooling is like maintaining a car. Keep doing water changes regularly, you are gonna be fine. Just a quick tip: Dont do a budget watercooling, if you are gonna do a watercooling loop, invest good money. I am in florida too, I gave up water cooing because the humidity inside the room from the AC outside also affects the radiators.
I need those 40 PCI-e express lanes.
https://linustechtips.com/topic/613539-help-plan-my-build/#findComment-7928275
If you are talking about the NZXT X61 then there is no maintenance required as they are sealed units.
A custom loop requires maintenance as you need to top up/change fluid every so often and clean it out, but they are a lot more expensive in the first place.
https://linustechtips.com/topic/613539-help-plan-my-build/#findComment-7928458
awesome... so i think the gameplan after all this is to figure out if the X61 will fit in my current case lol... if not then i'll need a backup plan.  But I'm digging the upgrade graphics card / move to watercooled solution and keep current system
https://linustechtips.com/topic/613539-help-plan-my-build/#findComment-7928701
What is your current case ?
https://linustechtips.com/topic/613539-help-plan-my-build/#findComment-7928945
It looks like it's very doable here is a video of a guy who did it.  I do know it has holes for watercooling on the inside which would indicate to me it's doable.  I suspect would mount the rad on the top of the system since it's a 2 fan solution.
Yet again... here is a video where they say there is no chance in hell
And... if I need to transplant the entire system what case would be recommended?
https://linustechtips.com/topic/613539-help-plan-my-build/#findComment-7928983
That 1st Video sounds like he said the cooler was an Antec 620. That is only a single 120mm radiator/fan so it would fit in the rear.
According to Thermaltake website the fan mounts in the roof are 120mm, so a 280mm such as the NZXT X61 wouldn't fit.
If you want a good replacement case then Phanteks Enthoo Pro/Luxe are very good, or if you want something more aggressive then check out the NZXT Noctis 450. Any of those will take the NZXT X61 or any other 280mm cooler.
https://linustechtips.com/topic/613539-help-plan-my-build/#findComment-7929152
Wow.... the Noctis 450 is a beautiful case!  It had me at hello.  I think I have an action plan now :)
Yeah it is a very nice case. You also get the benefit of a psu cover/shroud to hide all the ugly cables, and the internal hard drive/SSD bays are hidden so you get a much cleaner looking build. The LED lighting looks pretty cool as well.
https://linustechtips.com/topic/613539-help-plan-my-build/#findComment-7929172
