Hello. I recently put my radiator fans onto the motherboard so they can be turned off when the temperature is low.
I have set the radiator fans to turn on when they are 50c because when it was 40 and idle, they were on and off all the time. Is this a safe temperature to idle the CPU at/below?
Another question; In BIOS It wont let me reduce the speed of the fans below 60% and Its pretty loud whenever it comes on, (The reason why I increased the fan temperatures). Is it possible to make it so the fans can go below 60%? This is the most recent ASUS BIOS
i7-4790k
CPU - i7-4790k | CPU Cooler - NZXT Kraken X53 | Motherboard -  Asus Gyphon Z97 Armour Edition | RAM - Corsair Vengeance (2x8GB) 2400Mhz | Graphics Card - MSI GTX 1070 | Power Supply - Corsair CS750M | Storage - Seagate 1TB HDD | Samsung 500GB 850 Evo | Case - Fractal Design ARC Mini R2 | Colour Theme - Generic Red & Black
Operating System - Windows 10 Pro | Peripherals - Corsair RGB Mechanical K70 Keyboard/Corsair M65 Mouse
Click here to give a damn
https://linustechtips.com/topic/612958-max-idle-temperature/
1 minute ago, TheRandomness said:
Idle temps don't exactly matter. Load temps do, however.
So would you say it is safe for the fans to come on at 50c to cool it back down?
Also do you know how to make it so the fans can be turned on below 60%?
https://linustechtips.com/topic/612958-max-idle-temperature/#findComment-7921480
yes it's safe. for fan speed check the bios or use speedfan
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/612958-max-idle-temperature/#findComment-7921486
Yes. I look in BIOS, but the fans will not go below 60%. It just won't let me, its like its got a cap on 60%. It can go over, however.
This image is the fan curve (Before I set it for 50c) You can see that it won't let me go below 60% so it spikes up instead.
https://linustechtips.com/topic/612958-max-idle-temperature/#findComment-7921489
