Does all of these specs fit in the case and on each other
https://pcpartpicker.com/user/Wolfiowww/saved/WYP2FT
AND a gtx 1070
My main rig  Shardsedge
 ☟ INFO & SPECS
  • Information:
This build is made for video editing, Gaming and livestreaming.
probably 65% of this build has been bought used.
  • Specifications:
CPU  AMD Ryzen 7 1700
GPU  Sapphire RX 580 PULSE 4GB
SSD ✦ Toshiba TR200 240GB
HDD ✦ WD Black 160GB 2.5" + WD BLUE 1TB
PSU ✦ Corsair RM750X
RAM ✦ Corsair Vengeance LPX 2x4 (8GB) 3000Mhz
CASE ✦ Corsair Crystal 460X
MOBO MSI X370 SLI Plus
My old pc build  Smoke
 ☟ INFO & SPECS
  • Information:
This build was made for gaming especially, it was my second build.
i had some struggles livestreaming on it because the CPU just wasn't good enough for that.
(I do not have this build anymore)
  • Specifications:
CPU ✦ Intel i5 6500
GPU  Sapphire NITRO+ Radeon RX 470 4G D5
SSD ✦ Kingston SSDNow v300 120GB
HDD ✦ WD Blue 1TB
PSU ✦ Corsair CX450M
RAM ✦ Corsair Vengeance LPX 2x4 (8GB) 2400Mhz
CASE ✦ Sharkoon S25-V
MOBO ✦ MSI H110M ECO
https://linustechtips.com/topic/612901-does-it-fit/
1 minute ago, Kyle2202 said:
No gpu? But other than that it should all fit no problem, it's a pretty solid build.
gtx 1070
 ☟ INFO & SPECS
  • Information:
  • Specifications:
 ☟ INFO & SPECS
  • Information:
  • Specifications:
CPU ✦ Intel i5 6500
HDD ✦ WD Blue 1TB
https://linustechtips.com/topic/612901-does-it-fit/#findComment-7920985
you're good to go brother
awesome
 ☟ INFO & SPECS
  • Information:
  • Specifications:
 ☟ INFO & SPECS
  • Information:
  • Specifications:
CPU ✦ Intel i5 6500
HDD ✦ WD Blue 1TB
https://linustechtips.com/topic/612901-does-it-fit/#findComment-7920987
