Razer Ripsaw: How does work?
Go to solution Solved by 21rkosta,
do you know how an elgato works?, because it works in pretty much the exact same way as an elgato
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
btw love your username
12 minutes ago, LinusLateTips said:
ok so theres the razer ripsaw right, and can i only use it for streaming or recording just as well.
many thx.
admin gaben pls delete 5mins after answered
+1 for your username
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
check out this website
whyyoualwayslate.com
1 minute ago, LinusLateTips said:
I mean, has linus ever started the WAN show on time/
i dont think so xD
Old Rig
No... Why would they delete this when an answer is found? Things are left up so people encountering the issue themselves can google and find it.
Also you have a fantastic name lol
  • 5 weeks later...
1. Ok, didn't think of that.
2. Thanks, Linus pls start WAN show on time
