So I was planning on SLI'ing two EVGA GTX 1080 FTW's... Looks like that won't happen, because the PSU I have (EVGA 850 B2) only has two 8 pin power connectors and I would need four. Any ideas on what I can do? I'm buying a new PSU if I can't find a solution, thanks for feedback
AMD Ryzen 9 5900X | ASUS TUF GAMING X570-PRO | G.Skill Ripjaws V 2x16GB @3600MHz CL16 | AMD Radeon 6800 XT Cooler Master MasterCase Pro 5 w/ Tempered Glass | Samsung 970 Evo Plus 1TB + ADATA SU800 2TB | Corsair HX1000iNoctua NH-D15 chromax.black
https://linustechtips.com/topic/612663-not-enough-power-connectors/
Unless you threw away all the cables it should actually hav 4x8pin plus 2x6pin....
http://www.evga.com/products/Specs/PSU.aspx?pn=6c83d705-1398-48c1-bac2-329f94dec9e1
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Would 6 pins work? I don't want to risk anything
This is the layout by the way:
no 6pins would not work but your psu HAS 4x8pin. you just have to plug the cables in. (PSU layout isnt the same as cables really are)
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Sorry just noticed you said 4x8, no it doesn't
Ah okay thanks :) I'll look in my PSU box as I left some extra cables there
Yup. Each one of those VGA spots have 2x8pin cables
