It probably will. I would upgrade to an Athlon X4 860K. Since you have a GPU you won't need to pay the premium for an APU.
Main Rig: https://uk.pcpartpicker.com/list/kLDFqk
Server: Dell PowerEdge R710 / Intel Xeon X5675 @ 3.06GHz / 128GB DDR3 RAM / Dual RAID 5 Arrays (3x 1TB + 3x 2TB) for 6TB of Storage
Laptop: HP Pavilion x360 13-s150sa / 13" 1080p Display / i5 6200u / 128GB SSD / 8GB DDR3 RAM
Broadband: Virgin Media Vivid 350 (385 Mbps Down / 20 Mbps Up)
https://linustechtips.com/topic/612233-will-it-bottleneck/#findComment-7913803
The Athlon is FM2+ and the A8 is FM2 (not plus). Idk if those two are interchangeable, google it.
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/612233-will-it-bottleneck/#findComment-7913831
