Do not post multiple times.
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
"Till I started replacing wires" there's probably your problem. Check to make sure that they're not broken.
Can you get an image without your graphics card using the integrated graphics?
“The value of a college education is not the learning of many facts but the training of the mind to think”
woah...triple post!
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
If you have done something to the wiring and the moving of said wires, make sure you plugged them all in properly
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
Put everything back and it still does the same thing.
Reseat card. Try in another system. What PSU are you running?
This happened to me one time - if everything IN the system looks ok, are you sure the display is still ok? I had one die on me while working on a computer. Two hours later and happen to grab another monitor and presto...
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
everything look fine. Monitor work,graphic card fan is running,ssd green light is on.
I try two different monitor,try different display port,switch gfc to other pci slot,use different connectors. Nada
Dead card? RMA?
card was working earlier.
Could be popped now - try it in another system?
Bump
Bumping is against C.O.C.
put old cpu back in and it worked. Think I have a defect cpu.
That's a possible reason, try to RMA.
now i have a problem lol
I got a another new 8350 and it still does the same. my motherboard should be compatible with this possessor.
mobo=ga-990fxa-ud3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514
1. How did you get  new one so fast? And it might be the card, try to RMA it.
